I am working on the soft top for my 58 project.  A past owner put on a repro soft top and drilled out the threaded holes for the screws that attach the pads to the top surface of the bows.  He/she used rivets to secure the pad.  The holes that were drilled go all the way through the bow.  Is this correct?  It seems that they should not go all the wau through and I either fill, re-drill/tap new holes or use rivets also when I install the new top.  Any advice would be greatly appreciated.
Jim
Jim
