How does SL diesel compare to the CJ4, same, better or worse for our cars, thanks.
Duke, SL oil question
Tags: None
- Top
- Top
Re: Duke, SL oil question
The 'S' in 'SL' is for spark engines. The 'C' in 'CJ' is for compression engines, ie. diesels. I think.- Top
Series III oil was basically for Detroit Diesel two stroke cycle engines. I do not remember the main diferences but I do know that it had a lower ash content. If you put good oil in those old engines, you might as well carry a five gallon bucket with you for add oilDick Whittington- Top
this guy owned a bunch of dozers,graders and other stuff with diesel engines so he figured it was good enought for that stuff should be good enought for the race engine. i even gave him a case of D-A speed sport oil when he picked up the engine. stupid is as stupid does.Series III oil was basically for Detroit Diesel two stroke cycle engines. I do not remember the main diferences but I do know that it had a lower ash content. If you put good oil in those old engines, you might as well carry a five gallon bucket with you for add oil- Top
There were specific API C-category specs for those old Detroit Diesel two-strokes, but I believe they are long obsolete.
I know there are a lot of old Detroit Diesel two-strokes still in marine service, but I have no idea what currently available oil they should use.
"Low ash" means low additive levels since it's the additives that leave ash, not the base oils. So "low ash" is a no-no for vintage automotive engines with sliding surface valve trains that you want to last. This includes current aviation oils and old two-stroke diesel oils.
Here's a link to the latest edition of the API Engine Oil Guide that shows the history of both C and S-category oils from the beginning of this system's use, circa 1969, to the present:
The American Petroleum Institute (API) is the only national trade association that represents all aspects of America’s oil and natural gas industry. Our more than 600 corporate members, from the largest major oil company to the smallest of independents, come from all segments of the industry.
DukeLast edited by Duke W.; September 5, 2011, 02:09 PM.- Top
thank duke and others.Michael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
