harmonic balancer ID - NCRS Discussion Boards
  • Bob C.
    Infrequent User
    • April 30, 1999
    • 13
    My 66 300HP has a 6 1/8" X 3/4" balancer with the #3883__5 the 5th and 6th numbers are obscured by a bolt hole, the 6th number looks to be a 5 or 6. Does anyone know if this is the correct balancer for this engine?
    • 43246
    Re: harmonic balancer ID
    Bob------
    Well, I can tell you this: the original balancer for your engine was supposed to be GM #3883204. I can't see any way to get 3883204 out of "3883__5 with a possible 6th digit of 5 or 6.
    The balancer for 1966 283 applications was GM #3883956. Both balancers are the same OD and thickness. So, if the last digit seen on your balancer is actually a "6" and not a "5", I'd say the balancer you have is a 3883956. If you're sure it's a "5", then I'd say it's probably some PRODUCTION-only part number (POSSIBLY 3883955) and likely original to your engine.
    By the way, you are talking about a number STAMPED on the face of the balancer and not a casting number seen on the rear of the hub section of the balancer, aren't you?
    • Bob C.
      Infrequent User
      • April 30, 1999
      • 13
      Joe
      No, the numbers are on the rear. The only ones I see on the front are
      F D 6
      Bob
        • 43246
        Joe
        F D 6
        Bob
        Bob------
        The numbers on the rear of the balancer hub are casting numbers for the hub section. I believe several different balancers were manufactured with the same hub, so you can't ID a balancer from these numbers.
        I suspect your balancer is original.
        • David L.
          • July 31, 1980
          • 3310
          Bob,
          Your balancer sounds like it's an original dated "F D 6" where "D 6" = April 1966.
          I once owned an original balancer stamped "E 6 F" ("E 6" = May 1966) from an original 1966 Chevrolet 327 engine. I'm not sure the meaning of the letter "F" (possibly the vendor). See link below.
          Dave
          https://www.forums.ncrs.org/showthre...=2725#poststop
          • Bill H.
            • August 8, 2011
            • 439
            If this helps, pics of my 67, 300.
            The 388# is on the back of the balancer.
            FA7 is on the front (build date).
              • 43246
              Bill------
              Yes, this number on the rear of the hub is a casting number for the hub section of the balancer. It was very likely used for more than one finished balancer so it cannot, by itself, be used to identify a particular finished balancer.
              • Bill H.
                • August 8, 2011
                • 439
                Bill------
                Thanks, Joe. I pretty much figured that. Just put the pics up because it happened to be laying on the bench.
                There are no other numbers on the balancer. But there is a number on the rubber.
                • Timothy B.
                  • April 30, 1983
                  • 5193
                  If F A 7 is a date it's probably January 7, 1966, I think F is 1966. On my 67 the stamped #'s are D 7 F so I guess the date is April 7, 1966.
                  In the last post of this attachment is a picture of the date on my 1967 300hp balancer.
                  https://www.forums.ncrs.org/showthread.php?t=69629
                  • David L.
                    • July 31, 1980
                    • 3310
                    On the "F A 7" stamping the date code is "A 7" or January 1967. The letter "F" might be the vendor.
                    On the "D 7 F" stamping the date code is "D 7" or April 1967.
                    My balancer stamped "E 6 F" ("E 6" = May 1966) came off an original May 1966 327 engine.
                    Refer to the link in my previous post. The letter "F" seems to be common to many of these balancers.
                    Dave
                    • Timothy B.
                      • April 30, 1983
                      • 5193
                      Dave, The engine in my 67 is the original and the build date of the car is Sept 23,1966 so could the balancer be dated April 66 and not 67..
                      • David L.
                        • July 31, 1980
                        • 3310
                        Your "D7F" is dated April 1967.
                        The letter "F" is NOT part of the date code. Refer to the link on my 11:08 AM post today (09/05/2011).
                        Other balancers that I have or once had:
                        "7704", "B9F" (Feb. 1969)
                        "4684", "C8F" (March 1968)
                        "7706", "J8F" (Sept. 1968)
                        The 3947704, 3914684, and 3947706 balancers did NOT exist in 1966. Isn't it odd that all these balancers have the letter "F"? The letter "F" must be for the vendor.
                        Dave
                        • Timothy B.
                          • April 30, 1983
                          • 5193
                          Thanks David,
                          I find it hard to believe the balancer has been replaced but stamped #'s don't lie..
