dangling capacitor - NCRS Discussion Boards
dangling capacitor
  • Karl K.
    • November 17, 2008
    • 92
    dangling capacitor
    I remove my instrument cluster on my 65 coupe and found a capacitor hanging loose loose from a blue wire that is spliced into a brown wire behind the rt side of the cluster. Trying to find out where to attach it to, it has a bracket with a screw hole.
    Any help appreciated,
    Karl
  • Don H.
    Moderator
    • June 16, 2009
    • 2280
    Re: dangling capacitor
    Karl
    on page E371 - UPC U69 A5 of your 1965 AIM you will find the radio capacitor schematic. And see that your 1960960 capacitor attaches to a screw just to the left of the ignition switch in the lower right corner of your cluster.
      Karl
      Karl -
      That capacitor attaches to one of the cluster can screws just above the temperature gauge - see photo below, and your Assembly Manual, section U69, sheet A5, item #6.
        • 15631
        Karl
        Gee Karl when I first read your title I thought we were in for a grammar lesson. I guess the Editor in me is still barely alive.
        • Karl K.
          • November 17, 2008
          • 92
          Thanks for the help! I'm still getting used to the repair manual.
          • Don H.
            Moderator
            • June 16, 2009
            • 2280
            If you mean the Assembly Instruction Manual, good luck on that one. That book needs a separate instruction manual to explain how to find anything. An index would be a huge help. I think John H has explained the UPC system in the past, but I am too dense to make sense of it. However, once I have been able to locate the pertinent page, I can usually figure something out if I study it and think on it a bit.
            good luck
              good luck
              Don -
              Here's an article I wrote on how to understand and use the Assembly Manual - it should be helpful:
