1963-67 Front Rocker Molding Bracket - Where is this found (+ two rivets) in the AIM? - NCRS Discussion Boards
  • Scott S.
    • September 11, 2009
    • 1961
    There is a bracket attached to the front tip of the rocker panel area (rear of front wheel well) of the body panel fiberglass. It is attached with two rivets, and there is an off-white plastic/nylon nut inserted in the square opening on the bottom.
    Where is this located in the AIM?
    I thought it should be on 1ASM-F4, but I don't see it.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 1963-67 Front Rocker Molding Bracket - Where is this found (+ two rivets) in the
    Scott
    It typical for the rods to sit a bit twisted till full weight is on suspension. Movement back and forth helps too.
    Did you assemble the small cup washers that go on both sides of the bushings?
    • Scott S.
      • 1961
      Originally posted by Gene Manno (8571)
      Scott
      Gene,
      Thanks, the rubber looks so twisted and separated from the steel that it's hard to believe they're still okay.
      About the the small cup washers, I have a set from Bairs, forgot all about them. How do they fit? It doesn't look like there's any space between the steel part of the bushing and the strut rod bracket. Anyone have a picture of these installed?
      (thread is here: Problem with new Strut Rod Bushings - are these ruined?)
        Scott -
        It's on UPC 1 Bolt/Weld, sheet A10, item #12.
        • Scott S.
          • 1961
          Thanks John, I see it now. That assembly manual is an amazing book, with stuff hidden all over the place. Sometimes it's like finding Easter eggs
          • Patrick T.
            • September 30, 1999
            • 1286
            Ain't that the truth!
            • Alan D.
              • January 1, 2005
              • 2053
              Scott the thread is getting a little off subject however I think you are asking about what was pictured so here is an original 64 set up
              See c2 rocker molding bracket
              Goes over a lot go good details.
              • Scott S.
                • 1961
                Alan,
                Thank you for the link, that's it. The 1963 AIM shows this bracket (GM 3833355, 3833356) was added on 9-27-62, along with the pop-rivets (GM 3828470), and these same part numbers continued through 1967.
