My windshield wiper motor on my 1966 is not grounded for some reason. When I run a ground wire direct to the motor housing, with the wiper switch on, it will work. Without the ground wire all I get is a clicking noise when I turn the switch on. I have checked the wire connectors to the motor and they are all properly attached. As I understand it the ground connector (Black wire) comes from the blower motor. The ground connector at the blower motor has two black wires one for the blower motor and the other that goes to, I assume the wiper motor. I have checked the wires to the blower motor and it has continuity to ground but, the ground connector to the wiper motor does not. I have checked the continuity from the wiper plug and the blower plug to the entrance of the wire harness, using a pin to penetrate the wire and they both check out. There is no appearance of physical or heat damage to the harness between the blower motor and the wiper motor or any other harness. First, am I correct in my thinking that the wiper motor gets its ground from the blower motor? Second, does anyone have an idea as to what the issue may be other than that wire being severed somewhere in the harness?
Thanks in advance,
Jerry Larsen
Morada, CA
Thanks in advance,
Jerry Larsen
Morada, CA
