1965 Disc Brake Rotor Shield Color - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    I am taking my 65 apart for restoration and am looking for guidance on what color the disc brake rotor shields (f & R) should be plated. Mine are a dull gray whitish and definetely need restoration.
    Thanks for your help.
    Jim Blakely
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 1965 Disc Brake Rotor Shield Color
    If they have a "drip/run" look to the finish, that is original. I had mine cad plated (as in over restored) even tho they showed the original finish as shown in the attached thread.
    https://www.forums.ncrs.org/showthre...88533&uid=2708
      • 43247
      Jim Blakely
      Jim------
      The front shields were zinc or cadmium plated with no chromate (i.e. "gold") overplate.
      The rears were usually stamped of pre-punch galvanized material. In other words, galvanized sheet stock was used to fabricate the shields and no subsequent plating was performed. Manufactured in this manner, the very edges of the shield are bare metal.
      • Jimmy B.
        • July 31, 1980
        • 584
        Thanks for your speedy reply. I will give this information to my plater.
        Anyone ever use Steve Gregori who advertises in the "NCRS DRIVELINE"?
        • Stephen L.
          • May 31, 1984
          • 3162
          I've used Gregorie on a couple of occasions. Does good work and stands behind it.
