Correct Intake Mainfold Gasket - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    Can someone who knows tell me which is correct for my 1960 carbureted car?
    The first picture attached is off Corvette Centrals website and they say it is correct. The second is of an intake gasket that I bought in Carlisle and was told it is correct. Notice the tabs that are circled in blue.
    The TIM & GJ says "Manifold side gaskets should ahve a small tab to the left side of the exhaust gas crossover on each side. These tabs are rectangular with rounded corners."
    Was I misled from the vendor I bought the one in Carlisle from, and do I need to order another set?
    Seems like CC, Paragon, and Zip all look the same with a rounded top to the tab.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • William C.
    • May 31, 1975
    • 6037
    Re: Correct Intake Mainfold Gasket
    The picture shows a reproduction. The vertical rib is not present in the originals. Then there are the small "GM" logos molded into the end gaskets....
    Bill Clupper #618
    • Donald H.
      • November 2, 2009
      • 2594
      Yes, I know they are reproductions. What I wanted to know is either better for judging. Right now I have a Felpro gasket that Isn't close. I didn't know if one of these reproductions would loose less points in judging.
      Don Harris
      • William C.
        • May 31, 1975
        • 6037
        it would do better than the unmodified felpro. If I were you, I'd try to creatively remove the rib. I'd think an anvil and a suitable tool might help. Then all you need are the proper end gaskets.
        Bill Clupper #618
          • 11698
          The tab should be rounded like the CC photo, not square like the gasket you purchased. With a little creativity I think you can make this square tab into a round one. I'd put more effort into that than worrying about the rib, but that's just me.
          Patrick
          • Rod K.
            • 445
            Is there a source for the "GM" tabbed end seals?
            • Gary C.
              Administrator
              • October 1, 1982
              • 17971
              Here's what a 56-7 intake gasket "GM" tab looks like. Gary....
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Ronald L.
                • October 18, 2009
                • 3248
                Gary P in Florida has them.
                • Donald H.
                  • November 2, 2009
                  • 2594
                  I'll give him a call. That is who I bought the one I have with the square tabs from at Carlisle. Not sure why his are square if the correct is supposed to be round, but I will ask.
                  Don
                  Don Harris
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    I am referring to the end seals.
                    The side gaskets and how they need to be modified is a different topic which I believe you have suggestions on how to modify what you currently have.
                    • William C.
                      • May 31, 1975
                      • 6037
                      Square vs round on the side gaskets varies by year. I believe the JG for the respective years carries the correct description. I know the early solid axles were the rectangle, but don't have the changeover handy right now...
                      Bill Clupper #618
                      • Jerry C.
                        • November 1, 1995
                        • 741
                        I am under the understanding that the original gaskets had the square end as shown in picture #2. This is how GM could tell if the intake had been removed from a car under warranty. I think Gary had just cut of the rounded tab. I do 58-60 cars and this is my understanding. I have several sets of the end gaskets with the GM tabs.
                        • Gene M.
                          • April 1, 1985
                          • 4233
                          Bill covered the configuration of the tabs on early cars. Rounded tab on mid years. But the offering in your photo is totally wrong. The originals DO NOT have the ribbing at tab as in the photo and will not fool a judge that knows the difference.
                          • William C.
                            • May 31, 1975
                            • 6037
                            I agree that square were used thru '60, but sometime after that the production versions went to round. I also owned an NOS set of GM gaskets in the old black and gold packages that had the square tab, so I'm less certain that the warranty issue rings true.
                            Bill Clupper #618
                              • 11698
                              Noted.
                              I'm used to 63-and-up engines, at least with regard to the tabs.
