Correct coatings on reproduction trailing arm bolt and rear spring mount plate bolt - NCRS Discussion Boards
  • Jerod M.
    • March 10, 2011
    • 95
    On the right is a reproduction trailing arm bolt. On the left is a reproduction rear spring mount plate bolt.
    I have never seen the "real things", but the coatings on the fasteners don't seem correct. Could someone please let me know what the proper coatings should be?
    1971
  • Joseph M.
    • June 30, 1999
    • 334
    Re: Correct coatings on reproduction trailing arm bolt and rear spring mount plate bo
    Trailing arm bolts s/b cad/zinc. Leaf spring plate s/b black oxide.
    • Jerod M.
      • March 10, 2011
      • 95
      Thanks, Joseph. It's hard to tell in the picture, but do your trailing arm bolts have a tapered tip on them?
        • 3415
        Hi Jerod,
        In addition to Joseph's reply you may find the infrmation in the post by Joe L., that's part of this linked thread, useful.
        I don't know if you've seen it or not.
        https://www.forums.ncrs.org/showthre...+bolt&uid=2482
        • Joseph M.
          • June 30, 1999
          • 334
          The trailing arm bolts have a tapered rounded end. They should also have a hole for a cotter pin. Not sure where you got the bolts you displayed, but Paragon or AMK typically have, but not always, reproduction hardware with the correct finish and headmarkings.
            • 3415
            Hi Jerod,
            I looked at your picture again after your question and Joseph's reply.
            I notice the spring mouting bolts have a longer part of the bolt threaded than the originals. I'm not sure if this matters or not. Might the threads damage the side of the longer/lower spring leaves?
            These are replated originals, (and 1 of Terry M's cotter pins), from my 71.
            • Bill C.
              • July 15, 2007
              • 904
              hey
              just an FYI -- there is probably a good chance the repro bolts for the spring plate are going to be to long.
              Compare the new ones to your old originals. If the new ones are longer - DO NOT USE them. Get your old ones replated.
              Maybe they have gotten better with the bolt lengths now - but not sure.
              Bill
              • Jerod M.
                • March 10, 2011
                • 95
                Originally posted by Bill Chamberlain (47576)
                hey
                Bill
                Okay, I will check them. I only have two originals, so I was really hoping they were going to be correct.
                • Jerod M.
                  • March 10, 2011
                  • 95
                  I bought them from Ecklers. (foul or okay vendor?) They look correct, but I'm not sure about head markings. The zinc is bright rather than grey and no spangle. Big issue?
                  • Jerod M.
                    • March 10, 2011
                    • 95
                    Hi Jerod,
                    Thanks for this great link.
                    I see a theme...
                    Black Phosphate
                    Zinc
                    Plain
                    Looks like I need to order a black phosphate plating kit and a zinc plating kit. For the plain I assume I can degrease, wire wheel, and spray a light clear to prevent corrosion.
                      • 43199
                      I see a theme...
                      Black Phosphate
                      Zinc
                      Plain
                      Jerod-----
                      I wouldn't bother with re-plating. Paragon and their dealers have excellent reproductions of the trailing arm bolt and related parts as well as the spring retainer plate bolts. However, the trailing arm bolts you already have might be OK. I just can't see them well enough in your photo to say, for sure.
                        • 11616
                        I see a theme...
                        Black Phosphate
                        Zinc
                        Plain
                        The trailing arm bolts you show are already zinc plated, which is correct. Zinc plating is shiny silver - just go check out the zinc stuff in the hardware store. Much of today's zinc is shinier than many years ago, but it's the same stuff.
                        FYI, to remove the zinc from the spring bolts you can strip them with muriatic acid. It will bubble as the hydrogen is released, so watch out for acid spatter.
                        Patrick
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          Couple of things here...
                          Black oxide would not be a chassis finish as it has zero corrosion resistance. I see half way down we're talking of black phos which is the proper finish.
                          If you strip these bolts with acid...
                          Make sure you bake them to remove the hydrogen embrittlement, or you could have a catastrophic event.
                          Zinc today and yesterday....
                          Most of the fasteners back in this time period were just zinc, they had a corrosion requirement and the zinc coating had to be adequate to pass that spec. Later on yellow chromate or clear chromate were added as corrosion enhancers and those impart the blueish bright and or yellow look.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            If you plan to judge the car, you need to pay close attention to the head marks as the catalog stores just sell what ever and while you might get past a local show usually the national judges can know those differences.
                              • 43199
                              Ron------
                              I seriously doubt that any judge will ever see the headmarkings on these trailing arm pivot bolts except, perhaps, those doing a Survivor judging.
