hi,
i know that this has been discussed many times but i still can't come clear with the adjustment procedure of the headlight doors.
i've be wanting to remove/change the headlight bulbs/trim rings, renew the different springs/screws. to do this i need to remove the bezel.
my problem is that i can't remove the bezel as the door doesn't open up enough. i removed the clevis of the actuator, the different springs and undid the side arm.
i pulled up the door by hand but still can't get the front lip of the bezel flush with the body (locked position) to be able to remove it.
the headlight door sits perfectly in its opening when closed. headlight door ajar switch touches the tab.
what adjustment to make the door open more to make removal of the bezel possible?
thanks
thanks
