Re: Cannot install distributor to factory position
Duke,
My name is Randy Hebert and I purchased a 66-327 -350HP a couple of months ago. It ran pretty good but as a little rough. I decided to check the dwell and timing. Dwell was a little off, easy fix. Then I checked the timing and it was way off. Like seeing the mark at the top of the ballancer.
At least 30deg off the scale,Advanced.
I had the Vac line disconnected and pluged. I tried to adjust the distributor
and could not. I reindexed the dist a gear forward then went backwards. If I got the car running it ran like crap.
I checked the ballancer, Key way lined up with grove. Also verified top dead center, rotor position, and where the ballancer showed TDC. all was good.
I was begining to wonder about the motor as did Randall McCauley. A good friend of mine John Maggiore suggested I check the forum.
Well he sent me in the right direction. I read your reply to Randall.
I checked my car against your instructions and my point's werent even close to opening at all as your instructions indicated. I removed the gear as you instructed 180deg put back together. Then the point's were opening.
Started car and everthing fell into place. I was able to time tha car 10deg BTDC. It now runs great!!!
Thanks you for your post it bailed my butt out. Lost about 3 nights sleep
thinking about what was wrong. Your number 1 in my book.
Randy Hebert (24824)
Duke,My name is Randy Hebert and I purchased a 66-327 -350HP a couple of months ago. It ran pretty good but as a little rough. I decided to check the dwell and timing. Dwell was a little off, easy fix. Then I checked the timing and it was way off. Like seeing the mark at the top of the ballancer.
