67 Power Steering Cylinder finish - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Nothing in the Judging Guide on this. Was the power steering cylinder semi-gloss black, like the pump.
    It sure looks gray in the 67 service manual, but they didn't have color in the service manuals back then.
    Jerry Fuccillo
    • 43279
    Re: 67 Power Steering Cylinder finish
    Jerry-----
    Semi-gloss black. I've never seen one that was otherwise.
    By the way, I don't think they have color pictures in the service manuals to this day.
    • Gerard F.
      • June 30, 2004
      • 3806
      Thanks Joe,
      Semi-gloss black it is.
      Just refurbing the non-original I took off my 67 a few years ago when I had some leaks.
      I put on a imported one then. Guess what, the imported one has metric thread on the shaft, M10 x 1 thread. Can't find a castle nut to fit the thread.
      Jerry Fuccillo
      • Timothy B.
        • April 30, 1983
        • 5202
        Jerry, If the rod is not grooved in the center position the seal kit will work good. If there is a groove in the rod the leak will still be there and it's better to find a rebuilt cylinder.
        The only bad thing I see with the rebuild unit is the weld joint when assembling after they replace with the new rod.
          • 43279
          Thanks Joe,
          Jerry-----
          Are you sure the thread size is M10 X 1.0? I know of no such thread size. The only 10 mm thread size I know of is M10 X 1.5.
          • Gerard F.
            • June 30, 2004
            • 3806
            Joe
            I'm sure there is an M10X1.0 thread pitch, extra fine. After trying the 3/8 x 16 castle nut on the shaft to no avail, I've been in all the hardware bins around town. There is a 1.25 and a 1.5, and also a 1.0.
            Finally found a M10X1.0 hex nut in the bubble packed stuff at Orchard's Supply, that fits the shaft perfectly. But castle nuts in that size, nada.
            Jerry Fuccillo
              • 43279
              Joe
              Jerry------
              Yup, you're right. A M10 X 1.0 thread size does exist. It's very uncommon. I might be able to find you such a slotted nut. I'll let you know.
                • 43279
                Joe
                Jerry------
                I found some castle nuts of M10 X 1.0 thread size and they're on their way to me. Genuine GM, too. When I get them, I'll send you one.
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  Thanks Joe,
                  I'll owe you a lobster, next time in Essex
                  Jerry Fuccillo
