Good Saturday evening all.
The front pinion shaft seal on my '66 has a minute drip and will only get worse. Have read the procedure in the service manual on getting access to the pinion yoke by removing the snubber bracket. Not wanting to drill a hole in the floor board to remove the front bolt (one of two bolts supporting the carrier). Any one out there have in their "bag of tricks" (other than dropping the differential) an alternative suggestion on how to remove the front bolt.
Have got the drive shaft pulled and snubber cushion removed. Thanks.
(sorry Mike). Is the minute drip like one drop a month, or a drip a day?
