62 glove box - NCRS Discussion Boards
62 glove box
  • Roger B.
    • June 30, 1991
    • 82
    62 glove box
    I need advise on how to remove glove box lock. My lock does not have a hold to paperclip into as does the igination.
    thanks you
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: 62 glove box
    Roger,
    I use a kitchen jar-opener-rubber thingy to grab the outer round chrome bezel and unscrew it. If it's corroded in you may need penetrating fluid.
    Rich
    • Peter L.
      • May 31, 1983
      • 1930
      Re: 62 glove box
      Roger - Rich's suggestion is a good one and it will avoid scratching the paint on the compartment door.
      If the nut is stuck, another option is to take the door off and then on the bench looking at the back side of the door and lock case you'll see 2 rectangular holes (1 at 12 o'clock & the other is at 9 o'clock still looking from the back) near the front of the lock case where it steps down. You can see one of the holes in Rich's second photo.
      Next using the key turn the lock to the unlock position, remove the key, push in slightly on the push button and then using a paper clip, small screw drive, or dental tool push down on the top of the "keeper" (it looks like a tumbler) and hold it down while pulling on the push button and the push button, lock cylinder can be removed out the front of the case.
      Now you can get a better grip on the nut and hopefully remove it or you can use a large Allen wrench or a chisel with an 8 sided shank and a Crescent wrench to remove the"stubborn" nut.
      Have fun.
      Pete
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        Re: 62 glove box
        Pete, That's great info. I never knew that. I just did it on the bench here and it worked easily. A little wiggling after you push on the "keeper" and the lock cylinder came right out. Reinsertion just the opposite. Tighten the nut and insert the cylinder, push the keeper in and it's in.
        A few more pics below for reference.
        Rich
        • Peter L.
          • May 31, 1983
          • 1930
          Re: 62 glove box
          Rich - Glad it worked out. Great photos.
          It looks like someone worked on the nut without removing the lock cylinder first.
          If you haven't already, check on the lock cylinder because if it's an original, they usually have the KEY NUMBER stamped on them. Usually, the SERVICE replacement and reproduction ones don't.
          Pete
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            Re: 62 glove box
            Yes.....a prior owner/bubba used pliers on it. The cylinder is original with the keycode stamped in near the bottom.
              Re: 62 glove box
              Here's the tool we used in the plant to install/remove the bezel - octagonal bar stock welded to a socket.
              • Peter L.
                • May 31, 1983
                • 1930
                Re: 62 glove box
                Is that the Snap-On version?????????
                  Re: 62 glove box
                  Pete -
                  That's the St. Louis toolroom version - nowhere near as expensive as the Snap-On version.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11323
                    Re: 62 glove box
                    Cool tool John!..... you should put that up "For Rent" in the Driveline.
                    Rich
