Intake Manifold - NCRS Discussion Boards
Intake Manifold
  • Jerry W.
    • January 27, 2009
    • 588
    Re: Intake Manifold
    since this OP pertains to 62 340hp intakes...can anyone explain the pipe plug shown just below the thermostat housing in the pic below.( pic was posted on CF as original late build july 62 car )
    my 62 340 intake does not have this pipe plug or boss
      Re: Intake Manifold
      Originally posted by Robert Blowers (53573)
      Problem: I found the correct manifold #3795397 Alum. I ordered the listed carb #3269 Carter AFB. Not close to fitting on this manifold. Is there different models of the same number I have the 3269S H-1
      Robert -
      What's the nature of the fit problem? Linkage interference, or ?? Can you post a photo?
      • Robert B.
        Infrequent User
        • July 12, 2011
        • 18
        Re: Intake Manifold
        The base is a full 7/8" to wide left to right not close to fitting Not sure how to post a picture.
        • Mike E.
          • February 28, 1975
          • 5138
          Re: Intake Manifold
          I believe that it should be fitting just fine. It should mount on the inner set of holes not the outer. When mounted, the butterflies should open fine, etc.
          • Jerry W.
            • January 27, 2009
            • 588
            Re: Intake Manifold
            does this help ? mtg bolts not installed but it works
            • Terry D.
              • May 31, 1987
              • 2691
              Re: Intake Manifold
              Jerry
              Can you post pictures of the front and back of carb. I'm no carb expert (hopefully one of them will jump in) but that does not look like a 3269. Can you see any other numbers on rhe carb?
              • Jerry W.
                • January 27, 2009
                • 588
                Re: Intake Manifold
                Terry...these are only pics front and back i could find
                • Terry D.
                  • May 31, 1987
                  • 2691
                  Re: Intake Manifold
                  Jerry
                  Do the holes in the carb base line up with the manifold?
                  • Jerry W.
                    • January 27, 2009
                    • 588
                    #24
                    Re: Intake Manifold
                    Yep...holes line up..Carb. works fine...here's pic on dyno
                    Hope you're wrong about this not being a 3269...purchased from Chicago Corvette 2-1/2 years ago...was relieved when it functioned ok.
