I have a 67 327/350 very original roadster. Have owned since 1990. Rarely have I had any mechanical issues. I have been working on a high RPM miss and sent the original Holley off to be re-done. Put the carb on last winter and has ran great. Still have the high RPM miss but around town great. Last week went on a short ride and the car quit in the drive way and I could smell fuel.
Upon opening hood lots of fuel on the front of the carb. Mostly coming out of the rubber hinged plug on the front of the carb. Could not get the engine to run with out fuel pouring out.
What I have done so far:
Sent carb back and had the company check it out. It checked out with no issues. The rebuilder was Found from this forum and was great to work with.
Replaced the fuel pump which the carb guy recommended to see if too much pressure.
Tonight after putting carb and fuel pump on and starting I have the same issue. Car will run but fuel pouring out.
Any help will be appreciated before I have it towed to a shop.
Thanks.......
Thanks.......
