windshield washer pump fitting - source? - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    I need to replace the end fitting off the windshield washer pump (off white piece with three straight nipples).
    I am looking for a correct one piece replacement unit with similar coloring...any suggestions where to find one?
    (note...already tried eBay & the Corvette forum)
  • Steve D.
    • May 16, 2011
    • 106
    Re: windshield washer pump fitting - source?
    http://www.licorvette.com/
    Stoudts corvette 1 800 523 8485
    proteamcorvette.com
    • Joe R.
      • July 31, 1976
      • 4552
      Sorry, but NONE of the above vendors have the correct off-white part you are looking for. The above vendors have the milky white pump end that every judge deducts points for at any meet.
      The ONLY source for the correct off-white end is Restoration Service run by Steve Hackel at 1 708 687-4183.
      The only other source for that part would be any GM car of the 60's in any junkyard USA.
      JR
      • Steve D.
        • May 16, 2011
        • 106
        Proteam does have a large parts inventory. If no luck try wiperworks.net
