Using 58 under fender support on 60 - Judging hit? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2593
    I just ordered the support brackets that were used on 58s on the underside of the fender (under the fender top spear molding) to help prevent sagging. I am going to install on my 1960. We bought a new front clip from Sermersheim, already assembled, and there is enough sag in the fenders that it is noticable and the top fender molding doesn't fit right due to the sag.
    Can anyone address the judging implications of using this "foreign" part?
    The Judging Sheet has 60 originality points for "Condition of Fiberglass & Components". I assume I would not loose all of this. I've looked in the Corvette Judging Reference Manual and having no experience with the judging event, I can't really tell was the deduct would be.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Donald H.
    • November 2, 2009
    • 2593
    Re: Using 58 under fender support on 60 - Judging hit?
    Anyone have guidance?
    Don Harris
    • Ronald W.
      • July 31, 1993
      • 23
      I received a 4 point deduction at a regional meet for this mortification on my 61. At a chapter meet I got a 30 point deduction because the judge considered it a body mortification. I felt this was unfair since the reinforcement wasn't part of the body.
      • Donald H.
        • November 2, 2009
        • 2593
        Thanks, this is what're I needed to know. The 30 points seems very high. If I understand the score sheets, that was a 50% deduct for the whole body value.
        Don Harris
        • Steve V.
          • June 27, 2011
          • 95
          I am unfamilier with this part. Can you give me a CC part number? Will this help a fender that already has sag?
          Is there an alterternative way to fix the problem short of replacing the front clip?
          Steve
          Opportunity is missed by most people
          because it is dressed in overalls and looks like work.
          Thomas Edison
          • Donald H.
            • November 2, 2009
            • 2593
            Steve
            The CC part number is 331214. Picture from CC online catalog below. These came on 58s. They are riveted to the underside of the fender under the top fender molding. The molding studs actually go through these supports and bolt from underneath them. If you have sag along the top centerline of your fenders I would think these would help. That's what is going on with the front clip I got. Buying a new front clip may or may not solve the problem. Mine is brand new, assembled by Sermersheim and still has sag.
            Also, if you do decide to buy a new front clip, find someone to glue it together. I bought mine assembled from Sermersheim and my body/paint guy is having to take 80% of it back apart and reglue. The Sermersheim parts look good, and they are refunding the assembly charge and providing some new parts. But the assembly job was very careless in a number of places so I would recommend against buying it pre-assembled.
            Don Harris
            • Steve V.
              • June 27, 2011
              • 95
              Thanks for the reply Donald. BTW who is Sermersheim?
              Thomas Edison
              • Donald H.
                • November 2, 2009
                • 2593
                They make replacement fiberglass panels
                Don Harris
