The trim tag on this 69 looks ok, but I question the rivets and would like some comments if they are or are not correct. Thanks.
69 trim tag rivets
Re: 69 trim tag rivets
In some cars I have looked at I have noticed that the rivets have a small hole completely through in the center. In the picture I posted, note that there is only a shallow hole in the center. I did not know if this center hole would provide any indication with respect to being original or not.- Top
Robert------In some cars I have looked at I have noticed that the rivets have a small hole completely through in the center. In the picture I posted, note that there is only a shallow hole in the center. I did not know if this center hole would provide any indication with respect to being original or not.
If the hole appears "shallow", that means that the mandrel has not been expelled. This is fairly common with these trim plate rivets. If you press on it with a pin-like instrument, it will fall out the rear.In Appreciation of John Hinckley- Top
