ignition lock cylinder removal '63 - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    I need help with removing the lock cylinder from the ignition switch.
    What is the correct removal method for this year?
    Thanks, Dan
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: ignition lock cylinder removal '63
    The procedure might be in the service manual.... If its like a 67, there will be a small hole adjacent to the key hole. Insert a paperclip in that hole and turn the lock with the key. I don't recall the starting position for the key, but if you are in the correct position, you'll feel the compression of a small spring when you press on the paperclip. Holding the paperclip depressed, turn the key and the lock will come out of the holder. DON'T force anything. They come apart easily.
      On a '63, first insert the key and turn it fully counter-clockwise (to the "ACC" position); then, insert the paper clip in the hole, press against the spring load, and continue turning the key counter-clockwise - the cylinder will then release and come out of the housing.
      • Irby G.
        • November 1, 2001
        • 267
        Once you get it out, there should be 4 numbers etched on it (IIRC) which can be decoded to the correct keying. There was a gentleman that took that code from me and cut several keys for me that were dead on. If you need, I'll see if I can't dig up his name and phone number. It's been a few years since I had that done. He had some of the originals left. I believe the numbers are also supposed to be stamped on the key itself (again IIRC).
        • Daniel J.
          • July 29, 2007
          • 158
          perfect...got it removed & replaced with no problems. Thanks
