67 3 speed casting numbers - NCRS Discussion Boards
  • Rick M.
    • July 31, 1982
    • 39
    Can anyone tell me where to find a resource to determine the proper casting numbers (case, extension, cover) for a 1967 Corvette 3 speed Saginaw Transmission?
    I have a 3 speed with the ID of S7A05, case 3858986, extension 3860042. I assume it is from a Corvette.
    Last edited by Rick M.; August 14, 2011, 08:34 PM. Reason: Didn't give enough detail
    • 43279
    Re: 67 3 speed casting numbers
    Rick-----
    Those are the correct numbers for a 1967 Corvette 3 speed Saginaw transmission. However, the same transmission was used in other applications (just like the same Muncie 4 speeds used in Corvettes were used in other applications)
    • Rick M.
      • July 31, 1982
      • 39
      Joe:
      Thanks for the reply. I've checked all of my resource material and couldn't find the numbers listed, so thanks for the info.
