Is there a trick to removing the power steering pump from the vehicle.
I have the hoses disconnected. removed the belt, removed the two nuts from the studs on the rear of the pump, and the one bracket to pump bolt in the front of the pump. The pump is now loose in the bracket, but it keeps hanging up when I try to remove it. The bracket has this little slot for the inner attachment pump stud that looks like pump is just sitting there waiting to be lifted out.
Is there a certain way you have to orient it or twist it to get it out of the bracket, or do I have to loosen the bracket, or take the pulley off?
The service manual sounds so simple, after you remove the pump attacting nuts and bolts, remove it from the vehicle. ----but how
This is an add-on N-40 but looks exactly like the one in the 67 AIM.
Help!!!
I just know I'm going to feel foolish when I get the answer
Help!!!
