C3-rim question - NCRS Discussion Boards
C3-rim question
  • Dale P.
    • September 30, 1995
    • 248
    C3-rim question
    OK I am tired of running on the bias-ply tires and stock rims. my question is this, how much of a "handling" improvement will I get if I go to a 17 or 18" rim slightly wider tires and of course a high qualitity radial. is it worth the cost of new rims or am I better off just using the stock rims with radials?
    • 6940
    Re: C3-rim question
    Dale, I had 23555R17 tires on my 72 and the worked great, big improvement no matter what radial tire you install.
      • December 31, 1992
      • 15626
      Re: C3-rim question
      Define "handling". What are your objectives and how do you measure it?
        • January 31, 1988
        • 43196
        Re: C3-rim question
        Dan------
        If you're talking about basically street use, I'd use the stock rims with radial tires of the appropriate size.
          • May 31, 2002
          • 169
          Re: C3-rim question
          i OWN A 72 WHICH I RECENTLY PURCHASED NEW TIRES.
          I BOUGHT THE STOCK SIZE GOODYEARS WHICH I AM HAPPY
          WITH. Handling is just fine.....keep it stock.....
          Larger sizes won't make much of a difference.
          I say this because the handling of a 72 with newer suspension
          restored etc....works just fine.....Big John
          • Dale P.
            • 248
            Re: C3-rim question
            Duke.
            By handling I mean the car tends to be really impacted by any road imperfection. The slightest groove or dip pulls or pushes the car. Everything in the front end is in great condition. The alignment perfect. The power steering valve new. So my only other thought was very old bias ply tires. I want this car to be under control all the time so I can enjoy the drive vs fighting the road
            • Dale P.
              • 248
              Re: C3-rim question
              I guess I should have mentioned it is a 68 vette. yea I know one off year but it is the only way I felt that I could drive a big block without paying 100k
              • Dale P.
                • 248
                Re: C3-rim question
                Do you have any pictures you can share so I can get an idea of what that size rim looks like on the car ?
                  • December 31, 1992
                  • 15626
                  Re: C3-rim question
                  Any radial tire should eliminate or reduce such "tramlining" if the suspension components are in good shape and alignment is correct.
                  The size you should install is 215/70R-15 or 225/70R-15 and there are still a handful of higher speed rated tires in these sizes including the 215/70ZR-15 97W Pirelli P4000 Super Touring, but most are cheap, low quality S-rated tires. Higher speed rated tires, H and above, have a nylon wound cap belt that will virtually eliminate the possibility of a catastrophic tread separation, which makes high speed rated tires inherently safer even if you never exceed posted speed limits.
                  For radial tires, toe-in should be checked and reset to 1/32" per wheel.
                    • January 31, 1988
                    • 43196
                    Re: C3-rim question
                    Duke------
                    Hankook and Kumho offer H-rated tires in 215-70-15. I can't find any 225-70-15 that are above T-rated.
                    Not all S-rated tires are cheap. Although not in these sizes, Michilin has many S-rated tires that are at or near the top of the price range for a particular size.
                    • Dale P.
                      • 248
                      Re: C3-rim question
                      Ok. Now I am confused. S and T ratings? Plus when I talked to the local tire dealers they were all over the map with air pressure too. Any where from 28 to 35. I simply want a very good running and handling street tire that will handle well and ride without me beating me to death.
                      My plans are to use the car. Not just on nice weekends three times a year. I have owned this big block for many years and I only put maybe 1000 miles on it. Since it is a 68 and original bb I hadn't driven it much because I thought it would go up in value but it really hasn't so I am going to drive and enjoy it
                        • January 31, 1988
                        • 43196
                        Re: C3-rim question
                        Dale-----
                        Tires have speed ratings indicated by an alpha coding system. The most common rating is "S". This indicates a tire speed-rated to 112 MPH. The next higher rating is "T" which indicates a rating to 118 MPH. These are obviously adequate for street operation. However, higher rated tires don't just provide a higher speed rating. Basically, they "do everything better" than a lower rated tire and they have as part of their construction features which make them a somewhat safer tire.
                        The first rating which is really a "high performance" tire is "H". These tires are speed-rated to 130 MPH and include construction features that make them a somewhat safer tire. Beyond "H" are ratings of "V", "Z", "W", "Y", and "(Y)". The latter is rated to 186+ MPH.
                        I prefer an "H" or higher rated tire for a Corvette. However, they are becoming increasingly difficult to find in the 15" sizes used by all 1953-82 Corvettes. This can present a problem that can only be overcome by going to a larger size wheel which accommodates tire sizes for which "H" or above rated tires are available. I do not recommend such an approach, though. To me, a Corvette with larger wheels (and, consequently, lower aspect ratio tires) "looks funny". For me, if only "S" rated tires were available for 15" wheels, then I'd use "S" rated tires.
                        So, what about "S" rated tires? Well, they are what equips the vast majority of the cars on the road today. Auto manufacturers and most folks that use them consider them quite safe. I know of no general problem with them for street operation. I have used them for 1,000's of miles on my Corvette in the past and was 100% satisfied with them. If I were using them on the track, I might not be satisfied, but I'm not doing that and don't intend to.
                        As I pointed out previously, there are many expensive tires that are "S" rated. And, there are some fairly inexpensive tires that are "V" rated (although not in 15" sizes).
                        • Terry B.
                          • August 31, 1999
                          • 607
                          Re: C3-rim question
                          Dale,
                          You don't ever have to feel you need to apologize for a '68. I love mine.
                          Terry Buchanan
                          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                          Corvettes Owned:
                          1977 Coupe
                          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                          2003 Electron Blue Coupe
                          2019 Torch Red Grand Sport Coupe
                          • Rich C.
                            • December 31, 1993
                            • 383
                            Re: C3-rim question
                            I switched to BF Goodrich Comp T/A's several years ago. They've been great and the tire wear has been awesome! 215/70-15.
                            '73 LS-4 454
                              • January 31, 1988
                              • 43196
                              Re: C3-rim question
                              '73 LS-4 454
                              Rich-----
                              The Goodrich Comp T/A is no longer manufactured (hope you don't ruin a tire and need a single replacement). However, I believe in the 215-70-15 size they were "S" speed rated.
                              The Goodrich Radial T/A remains available and is available in the 215-70-15 size. However, it is also an "S" rated tire.
