Turn signal switch rebuilder? - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    Does anyone repair/rebuild them? I really don't like using the replacements with the adapter between the switch and body harness.
    Dan
  • Rich C.
    • January 1, 1994
    • 383
    Re: Turn signal switch rebuilder?
    I haven't tried it yet, but thought about removing wires from incorrect plug then transferring to the old original plug.
    • Stephen L.
      • May 31, 1984
      • 3162
      I replaced the wiring harness on a new switch with the original harness to maintain the flat ribbon and color codes. It is easy, just takes patience and good soldering techniques.
      I soldered the wires in a "staggered" configuration using heat shrink tubing to insulate the joints
      • Rich C.
        • January 1, 1994
        • 383
        That was my back-up plan!
        '73 LS-4 454
