igination switch 62 - NCRS Discussion Boards
igination switch 62
  • Roger B.
    • June 30, 1991
    • 82
    igination switch 62
    is there a fine thread on original iginations switchs.
    I have obtained a original 1 hole and the reproduction chrome nut
    does not thread on. It looks like original thread is fine and repro is course. Is this corrent.
    thanks
  • David L.
    • July 31, 1980
    • 3310
    Re: igination switch 62
    Roger,
    My 1963 Chevrolet Parts Catalog (effective Oct. 1962) lists ignition switch asm # 1116577 for 60-62 Corvettes in Gr. 2.188 and the ignition lock nut as # 3816982 in Gr. 2.198 for 60-63 Pass. cars and 60-63 Corvettes and described as "1-24 thd.-1 1/4 O.D." The switch PROBABLY has a casting "577" on it.
    The nut listed for the 53-56 Pass. and 53-59 Corvette is GM # 1929529 and described as "1-32 thd. - 1 11/32 O.D." The ignition switch for 57 Pass. and 58-59 Corvettes is listed as GM # 1116547. There should be a "547" casting number on the switch.
    Do you have the correct switch and is there a 3-digit number on it?
    Pictured is an original 3816982 nut with a "3816982" casting number on the back side that you need a magnifying glass to read. The O.D. measures 1.25".
    Dave
    • Roger B.
      • June 30, 1991
      • 82
      yes the # is 535
      thanks
      Roger
      • David L.
        • July 31, 1980
        • 3310
        Originally posted by Roger Behrens (19514)
        yes the # is 535
        thanks
        Roger
        Roger,
        It appears that your ignition switch is from a 1957 Chevrolet, GM # 1116535 as per my 1957 Chevrolet Parts Catalog (effective March 1957). The nut for this switch is GM # 3736482 and described as "1-32 thd. - 1 7/32 O.D.
        Apparently GM # 1116535 was replaced with GM # 1116547 sometime between March 1957 and October 1962.
        You do not have the correct ignition switch for your 1962.
        Dave
        • Peter L.
          • May 31, 1983
          • 1930
          Roger - I hadn't paid to much attention to the nut thread on the ignition switches. So I went to the part department and pulled a 60-62 switch and a 58-59 switch and found it interesting that the original ignition switch for the 60-62 Corvette which is a 1116577, embossed "577", has a coarse thread for the nut while the 1116547, embossed "547" used in 58-59 has a finer thread for the nut. Pete
          • David L.
            • July 31, 1980
            • 3310
            Pete,
            It does not surprise me that you have a "547" switch with 1-32 thd. as well as a "577" switch with 1-24 thd. in your collection.
            Dave
            • David L.
              • July 31, 1980
              • 3310
              Roger,
              Does your reproduction 60-63 Corvette chrome nut have the casting number "3816982" on the back side?
              Dave
              • Roger B.
                • June 30, 1991
                • 82
                I do not a number on the chrome nut.
                Roger
