can anyone quess the value of a original 68 radiator believed to be good to go?
68 original radiator value
Re: 68 original radiator value
Hi Roger,
To me the worth of the radiator would depend on the condition. '68's radiators could be either aluminum or copper depending on the engine, airconditioning or transmission and that might affect the cost. New ones from DeWitt cost $600 plus and come with a warranty. I don't think I would jump into the purchase of the one you described unless I had the unit pressure tested first to be sure it was not rotten. If it was a good unit, $300 might be a fair price. Perhaps a little more if it was NOS.
TerryTerry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
I would only use it if I did not drive the car. Good for judging , bad for driving. Even if it pressure tests, the inside may have deposit build up , flow may be ok, but it acts like a thermos bottle, hot water in, hot water out
Just my opinion.
Jack- Top
Aluminium radiators are stacked plate design with no side tanks and no filler neck or cap. Fender skirt surge tank required. Probably had a steel fan shroud. Aluminium shown (not the best pic)
Copper/brass radiators are huge, 4 row, with end tanks, filler neck, and cap. No surge tank on the fender skirt. Probably had a fiberglass shroud.
- Top
As Jack said above I would not plan on driving with an original aluminum radiator even if it held pressure. I think you will find it will run hot. Dewitts makes a reproduction unit that can be dated for your car and will pass judging why risk problems. Original is not always better.- Top
