de-chroming a FI air filter housing - NCRS Discussion Boards
  • Bill B.
    • December 1, 1993
    • 192
    I have a 62 original F.I. air filter housing that is chrome plated. Anyone have any methods for removing the plating without disturbing the original metal. Or to paint it, was suggested to use a self etching primer, followed by top coat, another suggestion, to have it powder coated. The plating is in good condition no flaking or chipping, just a little tarnished in some areas. What is the best way to tackle this?
    Bill
    1961 Black/Silver/Red Int. 283/315 FI power windows. Frame off 65% completed.
    1989 White/hard top/Grey Int. daily driver 167,000 miles
    "The problem with Liberalism is that eventually you run out of other people's money" - Margaret Thatcher
  • John N.
    • February 1, 1975
    • 451
    Re: de-chroming a FI air filter housing
    Bill
    Most chrome plating shops can remove the chrome.
    Regards
    • Bill B.
      • December 1, 1993
      • 192
      Ok John, good to know.
      Thanks, Bill
      • Bob J.
        • December 1, 1977
        • 720
        Bead blasting it prior to painting works also. Bob
        • Steven B.
          • June 30, 1982
          • 4011
          Bill, I have powder coated some engine parts on my auto X'r but on an original housing like your's I would strip and finish as factory.
          Good luck with it!
          Steve
          • Gerard F.
            • June 30, 2004
            • 3806
            Bill,
            You ought to try muriatic acid (pool acid) on it. I use muriatic with a 3 to 1 cut for removing zinc or cadmium from steel parts. It stops bubbling once it gets down to the steel.
            I undersand that it will also remove chrome, but maybe at a higher concentration. Worth a try, but do it outside as the fumes from the bubbles are toxic.
            Jerry Fuccillo
            • Bill B.
              • December 1, 1993
              • 192
              Thanks for the great ideas, Bill
              • Steve L.
                • June 30, 2001
                • 763
                Don't forget to let us know how it works out-good or bad.
                Steve L
                73 coupe since new
                Capital Corvette Club
                Ottawa, Canada
                • Bill B.
                  • December 1, 1993
                  • 192
                  Yes, I will keep you all informed either way. It may take a few weeks have other priorities.
                  Bill
