Ok, the guide says that the horns are metal but the flat part is plastic. I have the correct high note and low note numbers. Plus the correct date code and the correct welded bracket. But the horns are all metal.
What horns do I have on my 70
Re: What horns do I have on my 70
This will get you back to the top. I'm not a C3 guy, but I've never heard of a metal horn with a plastic bracket; someone will chime in.- Top
Steve,
Are the horns stamped "245" and "246" like the 1968-1969 horns? As far as I know the horns should be all metal. If the date codes on the horns are late 1969 or 1970 and the judging guide was printed within the couple of years I think you can guess what I would do with the judging guide.
My original 1970 Camaro horns ("289" and "290") are all metal.
Dave- Top
