tach cable grommet installation - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    Is there any way to insert a new tach cable through a new firewall grommet. Was wondering if possible to heat up the grommet, then use a sleeve of some sort to push it into the hole on the 4 hole replacement grommets. When I installed a new cable 20 years ago, I slit the grommet to fit over cable, hoping to avoid that!
    '73 LS4 454 Coupe
  • Rich C.
    • January 1, 1994
    • 383
    Re: tach cable grommet installation
    Nobody has done this???
    • Tom R.
      • December 20, 2010
      • 177
      Rich,
      I've used this tool from Long Island Corvette Supply
      http://www.licorvette.com/grommets_f...20Corvette.htm
      I used a little electric conduit lube on it first and it went through pretty easily without cutting the grommet. Just make sure the grommet is installed in the firewall first. It helps to have someone on the other side of the firewall to insure you don't poke the whole grommet out of its hole while pushing on the tach cable. Works for speedo too.
