1962 Corvette Temp. Sending Unit - NCRS Discussion Boards
  • Charles H.
    • January 1, 1989
    • 2
    Help! The temp gage on my 62 goes to full hot after a mile or two and stays there. I have checked tha actual engine temp with both a thermometer and an infra red sensor and the engine is at a proper 185 degrees, where it stays for as long as the car is run. I have checked the gage itself by shorting the lead wire to the block and it checks out fine. I have purchased no less than 4 additional sending units (two new and two supposed good used ones), all with the AC logo on them. They ALL behave in the same fashion!! What's up with that? I have heard that AC is now sourcing them from China and that their quality is poor. Sooo--Q1: What should the cold resistance of a good unit read(in ohms)? Q2: I have heard about adding your own external resistor to, in effect, bring the gage into calibration---but this sounds kluge and a little absurd. Q3: Where can I get a proper(read--good) sending unit? The one I got from Corvette Central is new and malfunctions as above. Regards, Chuck
  • David L.
    • July 31, 1980
    • 3310
    Re: 1962 Corvette Temp. Sending Unit
    Chuck,
    The temperature senders (GM # 1513321) sold over the counter in the 1980's and 1990's apparently do not give accurate readings. In the 1980's and early 1990's I collected about 15 senders from various 1959-1967 Chevrolet junk yard cars & trucks. I did some research and noticed that the stampings on these original senders varied but I could never correlated these stampings with specific years (see photos). The "type" shown in my research is my own terminology.
    As far as I know the only way to test them is to heat them in water at a varying temperatures and then measure the resistance while connected to a 12V DC source.
    I have four type "G" senders from a "3799349" intake dated "K302", a "3844459" intake dated "C135", a 1967 Chevy truck w/283, and a 1968 Chev. truck 6 cyl.
    The type "A", "B", "C", "D", "E", and "F" senders are from 1958-1961 Chevrolets.
    The type "H" is NOS (purchased 1980).
    The type "I" is NOS (box dated 1983).
    The Corvette Restorer also has articles about temperature senders.
    Vol. 11, No. 1, page 24
    Vol. 16, No. 4, page 14
    Vol. 16, No. 4, page 37
    The GM 1513321 sender is NOT used with 1962-1967 Chev. Passenger cars w/"idiot" lights.
    GM # 1513321 was replaced with GM # 546702 in Nov. 1970 which was then changed back to GM # 1513321 sometime in 1978 as per Chevrolet Parts History.
    Dave
    • Larry M.
      • January 1, 1992
      • 2701
      Charles:
      Your problem may not be in the sending unit, but could be an intermittent "short" in the tempertature sending unit to temperature gage wire when the engine gets hot. Grounding this sending wire will produce the same symtoms that you are seeing.....ie. the temperature reading pegs full scale. Try removing the sending wire from the sending unit the next time this happens and see if your gage changes. Also, hook a multimeter to the sending unit terminal and a good ground, and see what resistance the sending unit is indicating.
      The link below provides resistance versus temperature for this sending unit. Hope this helps.
      http://www.lbfun.com/warehouse/tech_...eCF-Thread.pdf
      PS: A Wells TU-5 sending unit is said by many to provide accurate readings and be rather inexpensive (cheap). Most auto parts stores sell these.
      Larry
      • David H.
        • November 11, 2009
        • 777
        Could this also be a grounding issue, maybe with the gauge in the dash or elsewhere?
          • 43278
          Chuck-----
          Are the temp sender threads in the manifold clean? Also, did you use any sealer or teflon tape on the threads?
          • Ken A.
            • July 31, 1986
            • 929
            Originally posted by Larry Mulder (20401)
            Charles:
            Larry
            The chart is incorrect.
            The GM prints spec'd the gauge at:
            Temp OHMS
            100 350
            180 105
            210 76
            240 72
            250 52
            This is what the gauge was built to and the sender needs to be close to these specs, as well.
            • Larry M.
              • January 1, 1992
              • 2701
              Ken:
              Which one?? I think there were over a dozen charts and tables in the article.
              Seems everyone today has a different specification or calibration. I guess that is part of the problem. The chart by Willcox at the end of the article I posted/linked was very close or the same as the information that you posted.
              Thanks for summarizing and keeping us straight.
              Larry
              • Ken A.
                • July 31, 1986
                • 929
                Larry,
                Didn't see his chart. The list I gave you is from a GM print dated 1966.
                This data is used to produce the "AC Delco" reproduction temp senders.
                Ken
                • Hank D.
                  • January 1, 1999
                  • 137
                  Chuck -
                  Regarding Q3 above, if you're certain there's no grounding issue, you may want to try a Wells TU5 sending unit available at Autozone. It solved the problem in my '60.
                  Hank
                  • Ronald W.
                    • April 6, 2010
                    • 37
                    Temp OHMS
                    100 350
                    180 105
                    210 76
                    240 72
                    250 52
                    The above resistance in ohms is lower than most of the aftermarket units I've tested. Do you know of any sending units available today that have a similar low resistance curve. (My gauge reads low so I need a sending unit with a low resistance curve.)
                    • Ken A.
                      • July 31, 1986
                      • 929
                      Paragon, Zip & CC all sell a sender that is correct.
                      • Scott K.
                        • February 1, 1980
                        • 59
                        We sell an adjustable resistor for issues like this. More info here.
                        Corvette Central
                        800-345-4122
                        www.corvettecentral.com
                        • Philip P.
                          • February 28, 2011
                          • 558
                          I think what Dave said is more likely problem rather than 4 sending units (possible but). If it is wired similar to a 1960 the power comes from the iginiton switch to the guage (may be tied to fuel gauge) then gets its ground thru the sending unit(resistance). If it goes full hot I would check the wire from the sending unit to guage (bypass it see what happens).
                          Phil
                          • Philip P.
                            • February 28, 2011
                            • 558
                            Another possibility is the guage contact is shorting out (ground) when it gets hot. The insulation around the guage contact could be breaking down and when it get hot it shorts to the case causing the guage to read full scale. It could then be getting ground thru the lamp base or the instrument housing. Just a thought.
                            Phil
