TUNG-SOL Flasher - NCRS Discussion Boards
TUNG-SOL Flasher
  • John F.
    • March 23, 2008
    • 2408
    TUNG-SOL Flasher
    Is this flasher correct for an early 62 (#29)? TUNG-SOL FLASHER, AP376V--12 VOLTS, 6 8 1, PAT. 2615106, MADE IN USA, two prongs with 3 LAMP on the top in a circle?
    After further clean-up with a light wire brush it is in fact an AP373V--12.
  • Bill O.
    • April 1, 2006
    • 542
    Re: TUNG-SOL Flasher
    John,
    I don't think thats the one. I think you are looking for a rectangular shaped Signal -Stat, ZN332 - 12V, 3 lamp. If you need a jpg let me know. Others may know better, but that's what I have on my October 9, 1961 built '62.
    • Kevin P.
      • November 1, 1975
      • 86
      John, I think the one you have is a AP373V witch is correct for your car.
      Kevin (775)
      • David L.
        • July 31, 1980
        • 3310
        1961-1963 Corvettes and certain other 59-63 Chevrolet models used a GM # 3758682 flasher. It was made by 2 different vendors with 3 different part numbers as follows:
        Tung Sol AP373V
        Signal Stat ZN332
        Signal Stat 143
        I have had one NOS ZN332 and one NOS 143 in GM yellow & gold boxes with the same GM part number, 3758682. My 1963 Chev. parts catalog (Oct. 62) lists the AP373V flasher as GM # 3758682.
        The "can" length of a AP373V flasher measures 0.87" in length. I have had many NOS AP373V flashers in Tung Sol boxes as well as several that were used from junk yard cars. The date code has yet to be decoded by anyone as far as I know.
        Dave
        • John F.
          • March 23, 2008
          • 2408
          David & Kevin, Thank you for the info. I took a light wire brush to the can and it is an AP373V--12. I can see it with the manifiying glass now. So I guess it is correct for my car!
          John F
          • Anthony P.
            • June 27, 2010
            • 485
            Are all 3 of these correct for a 62? (in my case a May 62 built)
            Tung Sol AP373V
            Signal Stat ZN332
            Signal Stat 143
            Or just the Tung Sol AP373V one?
            Tony
            • Kevin P.
              • November 1, 1975
              • 86
              I believe all 3 are correct but you should check the 61-62 judging guide to see what will judge correct. Kevin (775)
              • John T.
                NCRS Financial Officer
                • January 1, 1983
                • 291
                In theory all 3 are possible. The one most often seen in Bowtie cars is the ZN332.
                Hope this helps
                John
                • John F.
                  • March 23, 2008
                  • 2408
                  I don't see anything in the Judging Manual, unless I missed it.
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    John - If you haven't already, look in the AIM and see if there is more than 1 part number called out for the FLASHER ASM. I know in the 63-67 Corvette AIMs there are 2 flasher p/ns called out, i.e. ####### FLASHER ASM &
                    ####### OPT if back up lamps were standard equipment and on cars where BU lamps were not standard, there are 2 p/ns called out in the FUSE PANEL UPC and another 2 p/ns called out in the UPC where the BU lamp accessory is describe.
                    Remember the cars were generally built according to the AIM not to the TIM&JG. Also, remember GM was in business to make $$$$$$$$ not cars, and failure to have a single source supplier for an item like a flasher which if the supplier had a problem would cause production not to be able to ship cars wasn't a good idea.
                    Pete
                    • David L.
                      • July 31, 1980
                      • 3310
                      The 1962 AIM (Sect. 12, sheet 12.00) lists 3758682 and 3758683 as the GM part numbers for the flasher.
                      Dave
                      • Peter L.
                        • May 31, 1983
                        • 1930
                        Dave - Thanks for the info. I'd say with 2 part numbers being called out in the AIM that the Signal -Stat, ZN332 - 12V, 3 lamp flasher isn't the only flasher used in production, although it might have been the predominant one. Pete
                        • David L.
                          • July 31, 1980
                          • 3310
                          Pete,
                          Back in the old days (1950's & 1960's) when GM used the gold/black boxes the ZN332 and the 143 flashers came in the same box with the same part number, GM # 3758682.
                          Dave
                          • Peter L.
                            • May 31, 1983
                            • 1930
                            Dave - I just checked my Oct. 1, 1966 P&A 30 and it shows 3758682 as FLASHER, controls 3 bulbs only (AP373V) which is a Tung-Sol flasher. I thought I had seen an old box with the 3758682 p/n with a Tung-Sol flasher in it. I will check. So many flashers and so little time. Pete
                            • David L.
                              • July 31, 1980
                              • 3310
                              Pete,
                              As best as I can remember the two NOS flashers (ZN332 and 143) pictured in the gold/black 3758682 GM boxes are now in your collection instead of mine.
                              Dave
