PV and Side Glass Regulator Noise - NCRS Discussion Boards
  • Jeff B.
    • November 6, 2008
    • 154
    I'm preparing for the PV at the CA capitol regional in October and my 64 has some regulator (spring) noise when operating the side glass. When I restored the car I did not change the regulator coil springs, I just cleanded an lubed them - still there is a little noise as the spring coils and uncoils. The PV guide talks about smoothness of operation and freeplay but does not discuss noise during operation. Just wondering if I need to pull them back out and change the springs.
  • Joe R.
    • July 31, 1976
    • 4550
    Re: PV and Side Glass Regulator Noise
    Jeff,
    I think I would just pull the door panel and take some axle grease to them before going to the trouble of pulling them out. As I recall, they were gobbed (good word) with grease or something thick along that line. Probably old grease that had hardened.
    JR
    • Dan H.
      • July 31, 1977
      • 1369
      Originally posted by Joe Ray (1011)
      Jeff,
      JR
      Totally agree! My 64 windows were binding etc. Removed door panel etc. and located the spring, then flooded it with a spray can of white lithium grease. Presto, silky smooth. Give it a try!
      Dan
      1964 Red FI Coupe, DUNTOV '09
      • Jeff B.
        • November 6, 2008
        • 154
        OK, I did the passenger door tonight and it took some effort to work the grease into the spring coil but the sound is gone! I thought had done that when I had the regulators out the first time but I guess I was to stingy with the lube. One more thing off of the old PV check list. Thanks for the responses.
