Exhaust pipe expansion - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    63 convertible_
    I bought new secondary pipes (2.5 in) which require that the forward ends be expanded to accept the front pipe that attaches to the manifold. I am using an expander driven by a neumatic wrench. I can only get about 100 psi out of my compressor, and have reached a point where the pipe will not expand any further. It's close, but needs a bit more expanding. Do I need more air pressure to the wrench or perhaps add some heat"? Any tips appreciated.
    Steve
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Exhaust pipe expansion
    Take the pipes to a muffler shop, for a few bucks they can make them the correct size.
    • Steve D.
      • February 1, 2002
      • 990
      That's a reasonable assumption, but it didn't work for me
      • Michael W.
        • April 1, 1997
        • 4290
        Long box end wrenches or breaker bars will give you more torque than a 100psi impact gun.
        • Steve D.
          • February 1, 2002
          • 990
          I started with a breaker bar, but don't have a jig to hold the pipe in place; just a vice. The 100 PSI limit can be remedied by fixing the leak in my compressor regulator. Since I had not doe this before, I am a bit timid; concerned about spliting the pipe. But since the shop got the previous pipe sloppy big, I guess I shouldn't be worring about that.
            • 43289
            Steve-----
            I would not operate the impact tool at any higher pressure than the instructions for that particular tool state. Often times, this pressure will be found on a label or embossment on the tool.
