70 Coupe hand written marking. - NCRS Discussion Boards
  • Mike F.
    • April 25, 2011
    • 668
    For any who may be interested, found this on the rear license plate body panel. 70 May built coupe.
    Mike
  • R N.
    • May 31, 2002
    • 640
    Re: 70 Coupe hand written marking.
    Thanks for sharring Mike.
    The 1970 Corvette Registry has other examples. http://www.1970corvetteregistry.org/
    • Mike F.
      • April 25, 2011
      • 668
      Found another after removing the fuel tank. Passenger side, aft side of the storage compartment bulkhead looking forward (270???).
      Part number and yellow dot, underneath aft deck, above fuel tank, driver side (looking up from ground).
      Question; Is there a reason I can't edit my posts after 12-24 hours?
        • 15637
        This one is your job number. You will find the same handwritten number behind the heat shield on the engine compartment side of the passenger's side toe board.
        You can not edit your posts after some length of time has passed because that is the policy of this (and most other) board(s). That policy prevents someone responding to your post and then you changing that post and their response then makes no sense or makes them look foolish. It tends to maintain the civility of this place.
