I was going home from work earlier this week, when i tried to turn the key in the ignition, the key got stuck right away as i tried to turn it. I thought i put it in upside down. I took the key out and reinserted it and the car started no problem! All the locks were replaced 3 years ago, and the ignition lock was put on upside down.. So i would put the key in upside down.. no problem so i thought... Now i dont know if the tumbler was actually put in wrong, or the whole unit was off by 180 degrees, so the key needed to be turned upside down to function.
The next day i insterted the key and it wouldnt budge... and i havent been able to start it or remove the ignition assembly from the dash..
Luckily it was in my garage.. although i was late for work.
I did read many posts posts like the exerpt below, about how to remove the lock..
"insert key back into the switch, turn to off position , then insert a very small pin or a small cotter key into the small hole in the ingnition switch bezel, then turn the cylinder, with the key and with the cotter derpressed(its against spring pressure)in a counterclockwise direction and then pull the cylinder out of the ingition switch. would also remove the ingition switch which can be disassembled , cleaned and lubricated with silicone paste. usually its just dirt or crud . if its the key cylinder, you'll probably need a locksmith. much cheaper to remove the cylinder and take it to locksmith than have the old boy stop by to work on your vet. good luck, mike"
My problem is that i can feel the spring mving in, with the key in when i insert a large paperclip but the cylinder wont move in any directon, even to get it out.. if it does move the whole unit spins together. I am not sure where it is stuck but after fidling with it for a few hours it could be between the off and on position.
Any suggestions on what i can try short of calling a locksmith to remove it from the dash ?
Just added two pics, one is with the hole in the ignition face at 2 o'clock and the other is the rear of the ignition lock assembly at the same orientation.. they will not move independently..
Joe
Joe
