C1 HD front coil spring dimensions & gauge? - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1141
    Does anyone know what the dimensions are for the HD front coil spring? i.e. # of coils, thickness of the coils? Would a standard Chevy front spring, cut to length approximate the HD front coil?
    I recently bought a Chevy front end to replace the front end parts on my '59 and I notice the regular coil spring is a little thicker and longer than the Corvette coil spring.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: C1 HD front coil spring dimensions & gauge?
    Ian,
    I sold a set of Corvette heavy duty springs a few years ago.
    They were marked with 3 green or gray paint dabs and the spring wire diameter was larger then standard springs and the free hight was also different. I do not recall the actual dimensions.
      Ian -
      Chevy specs show the RPO H.D. front springs as:
      .636" wire diameter
      8.75 coils
      4.44" outside diameter
      11.18" free height
      550#/inch rate
      • Gary C.
        Administrator
        • October 1, 1982
        • 17971
        Standard Corvette front coil spring is .55 diameter and 13 3/4" tall.
        Maybe John has specs on passenger car springs.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Ian G.
          • September 3, 2007
          • 1141
          That would be super helpful. John do you have the specs on passenger springs for comparison? If I can just cut this sucker down it would be very cool I want to do that later after I get judged
            Ian -
            No, I don't, but Tom Parsons might.
            • Tom P.
              • April 1, 1980
              • 1828
              Ian -
              I'll check and see if I have some pass car coils in the storage building, but in the meantime, John Neas probably knows because he had SOMEONE/SOMEPLACE make 3 sets of springs, all three with different specs/ratings for the (Bark Henry) 57 Airbox racecar that he restored. He had me rebuild the frontend for that car.
              • Tom P.
                • April 1, 1980
                • 1828
                I had a set of (chrome) passenger car front coils.
                Passenger (left)--14 3/16in high, .585in diameter wire
                Vette------------13 3/4in high, .550in diameter wire
                Since pass car springs are between the diameter of stock Vette and HD Vette coils, I'm sure that pass car springs could be cut down to be used in a Vette, but I have ZERO clue what free height would be suitable. If a person wanted to use cut down pass car coils, it would just have to be trial and error. Obviously, they would need to be shorter than stock Vette coils (since they are made from heavier wire) but not as short as HD Vette coils.
                • Ian G.
                  • September 3, 2007
                  • 1141
                  Thanks Tom, that's good enough for me. My main goal was to find out if passenger coils were the same diameter as HD coils, since I noticed they were thicker. If they aren't I won't try and use them...
                  Thanks guys!
