A Belgium friend of mine has problems adjusting the three carburators on his '54 Vette. Is there an adjustment procedure somewhere documented he can use (manual, online, elsewhere???).
He gets the first two adjusted but when the third one is done it spills over. The engine also sweats a lot...
Help would be appreciated!
regards,
Rob.
regards,
Rob.
. Then, the adjustments must happen in a set sequence.
