Finish on Accelerator cable clamp - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    This is for a 73 SB;
    This bolts onto the carburator.
    I've looked at my original for at least 15 minutes. some parts of it look like natural, others (under the bolt) looks like zinc. Yet there appears to be a hint of green chromate.
    As I remember, it seemed to blend more into the carburator color.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Finish on Accelerator cable clamp
    Steve, I am not sure what part you are asking about. Is it the clamp that bolts to the LH rear carb bolt or the clip on the forward end of the cable where it pop[s onto the swivel?
      • 43288
      Steve-----
      If you're referring to the GM #3921617 clamp, every example I've ever seen was zinc plated with no chromate overplate.
      • Steve L.
        • June 30, 2001
        • 763
        This clamp is 3992386 in the AIM and stamped on the bracket and is attached to the left rear carb bolt along with the brake booster vac tube.
        Steve L
        73 coupe since new
        Ottawa, Canada
        • Russ S.
          • April 30, 1982
          • 2163
          Steve, This bracket is a grayish color with a slight sparkle to it on both cars. Probably is a grey phosphate.
            • 43288
            Steve-----
            That's not a clamp; it's a BRACKET. Every one I've seen, including several NOS examples I have, are as Russ describes------gray phosphate.
            • Steve L.
              • June 30, 2001
              • 763
              Joe, your right. I keep thinking it is a clamp because it clamps the cable.
              Black phosphate ii is.
              Thanks All
              Steve L
              73 coupe since new
              Ottawa, Canada
              • Russ S.
                • April 30, 1982
                • 2163
                Thanks All
                No Steve- Gray phosphate.
