1968 327/ 350 Corvette Thermostat Housing? - NCRS Discussion Boards
    • 43259
    Re: 1968 327/ 350 Corvette Thermostat Housing?
    Originally posted by Jeff Pollard (15573)
    While on the subject,what was used as a gasket.was it silicone or cork? Thanks,jeff
    Jeff------
    It was neither. My recollection of the original gasket is that it was dark gray, "composition" material very similar to the gasket material in the attached photo. I think it contained asbestos although the material pictured does not.
    I do not recommend the original type gaskets as they are EXTREMELY difficult to remove. Instead, use the current GM gasket which is a fiberboard material with a silicone rubber sealing bead. MUCH better in every way. GM #10105135.
    • Jeff P.
      • 799
      Thank you as always Joe.
      68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
      2014 Arctic White Z51 Vert. (Wifes)
