1970 - NCRS Discussion Boards
1970
  • Jeff S.
    • February 1, 2005
    • 73
    1970
    What type of grease should be used for the window run channel and regulator? Thanks
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1970
    I used white because that is all I had at the time. Not sure if it matters.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Paul J.
      • September 9, 2008
      • 2091
      Re: 1970
      White lithium grease is the standard, and I believe that GM had it's own version. The brand does'nt matter. Use it sparingly.
      • Greg A.
        • June 30, 1998
        • 141
        Re: 1970
        White, lithium-thickened grease is the usual stuff you can find in most auto parts stores. It comes in many dispensing styles, including spray cans, which may be the easiest method if your parts are still in the door. BTW, lithium is preferred as lithium-soap thickener is compatible with most all other thickener types and if you're adding it to some unknown old grease, it won't pose a compatibility problem.
