I pulled the clutch cross shaft to rebuild it. there was a washer between the frame side stud and the bracket. The rebuild kit from Corvette Central has two felt seals that apparently go on both ends of the shaft. My shaft did not have these felt seals to begin with and the Assembly manual does not show them either. So what is the correct shaft setup suppost to be? Should I install the feft seals?
Thanks for any help in this matter.
