I reviewed a lot of the threads and tried almost everything I could figure.
Here is what is happening. All with engine running.
Wiper door will not open or close via wiper switch or override switch.
If I manually push the actuator open with the wiper switch in the car on, the wipers work. When I shut off the wipers the door will close. If I then turn the wiper switch on nothing happens. I hear a click and when I turn the wiper switch on I can hear and feel the solenoid fire. The wipers parked properly.
If I manually push the actuator door open without the engine running it is still holding enough vacuum to close the door. The three port switch is still depressed with wipers parked so I would think this part is correct.
I have the Dr.Rebuild vacuum door diagram illustration and all appears correct.
Headlights work perfectly
Anyone run in to the same or a similar problem? Any suggestions are greatly appreciated.
Bill
Bill
