'63 Transmission, Is This Correct? - NCRS Discussion Boards
  • Rockland B.
    • July 28, 2011
    • 4
    How can I confirm this is the correct or original transmission for my 1963 Coup, I attached a pic, the numbers match, however its odd one stamp is slightly over the other?
    Thx.....Rocky
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: '63 Transmission, Is This Correct?
    Rocky,
    The stamp looks fine to me, I have seen this before. The W= Warner, B= February, 13= day of the month, 3= 1963 and 1= shift.
    The other stamp, (serial #) should be exactly like the stamp on the block pad..
    • Rockland B.
      • July 28, 2011
      • 4
      Thanks Tim, It was mentioned me that this might be a re-stamp, I am not sure why or how that would be the case? Any ideas?
      • Timothy B.
        • April 30, 1983
        • 5203
        Rocky,
        Others may have another opinion about restamp but it looks fine to me. Look closely at the engine stamp and compare as I believe it was done at the same time with the same stamp.
        • Loren L.
          • April 30, 1976
          • 4104
          What are the other markings and dates? Can you confirm that the "1" in the assembly stamp has a "base", ie, not like the vertical "1" in the VIN? The "3"s are different which is correct.
          The original T-10 in my #10706 car was assembled the day AFTER yours.
          Is there a stamping on the flat surface of the tailshaft just above the reverse lever? Casting date on "tape", RH side and upside down? Bowtie?
          I assume the trans is in the car so you could not see a stamping on the top of the main case on the right side.
          • Rockland B.
            • July 28, 2011
            • 4
            Loren, 3 more pics, let me know if this helps.......Thx....Rocky
              • 43290
              Thx.....Rocky
              Rocky-----
              I have no doubt this is the original transmission installed in your car.
                Thx.....Rocky
                Rockland -
                I had looked at that photo a couple of days ago (for Jerry M), and questioned the location of the date stamp; with the photo upside-down, it appeared to be on the midplate instead of on the main case. Turning the photo right-side-up, it's clear that the stamp is where it belongs. Looks good to me.
                • Timothy B.
                  • April 30, 1983
                  • 5203
                  Rocky,
                  From what I can see of the engine pad stamp I think they are identical so you are good to go IMO. The spacing of the 1's look the same as well as the 38 part of the stamp # being lower in the stamp.
