66 427 L72 + Battery Cable Routing - NCRS Discussion Boards
  • John M.
    • April 30, 2004
    • 111
    Can anyone confirm the exact routing for 66 L72 positive battery cable / speedo cable / solinoid harness routing?? Also were all of the firewall clips riveted to the firewall?? For 66 427 the AIM (UPC 12 page A6) shows the positive cable clearly routed from the + post thru a plastic clip on the side of the batt heat shield to the starter. Further in the AIM - for L72 spec hi perf (UPC L72 page D6) it shows the same + cable routed from the + to a clip on the firewall (just level with the furthest pass side bellhousing bolt) then to the starter - so apparently the heat shield was not used to locate the + cable for the L72. The judging manual references small block routing thru the heatshield clip but makes no mention that I could find re big block routing. In addition - I beleive the speedo cable and the solinoid harness shared the same firewall clip which is located higher up from the + batt firewall clip approximately center or the passenger side rear cylinder head. Do you agree with the above routing interpretation and is this a well known re judging criteria? My BB has this wiring set up and I am curious if it is correct.
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 66 427 L72 + Battery Cable Routing
    John, do you have the latest version #5 of the 66 JG?
    • John M.
      • April 30, 2004
      • 111
      Hi Ron,
      No I do not! Can you look at your '66 and tell me if the two clips on the firewall for the positive battery cable and starter harness are held on with rivits or screws??
      • Ronald L.
        • October 18, 2009
        • 3248
        John, I'll look this evening at both documents and the car, I expect the one clip is a hex head screw.
          John -
          The BB battery cable clip in View "A", L72, sheet D6, is attached with a pop-rivet. The 4-speed speedo cable clip, also pop-riveted, is shown in section M20, sheet A4. The clip on the lower heater blower housing stud (UPC 12, sheet A9, item #22) is only for the starter harness.
          • Michael H.
            • January 29, 2008
            • 7477
            The speedo cable clip/retainer on my 66 appears to be attached with a steel rivet.
            The battery cable clip is attached with a pop rivet. Difficult to see though.
            As John H mentioned, the starter solenoid wires run through their own clip that attaches to a lower heater case stud.
            • Ronald L.
              • October 18, 2009
              • 3248
              Here's a surviving dash clip.
              • John M.
                • April 30, 2004
                • 111
                Ron, is your battery cable and speedo cable clips held on with pop rivits or hex head screws??
                • Michael H.
                  • January 29, 2008
                  • 7477
                  John,
                  What type of rivets/fasteners are used for the clips in your 66?
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    John,
                    The upper looks to be solid and pulled through from the inside where the lower looks like more of a pop rivet pulled from the outside and consistent with that Michael is saying above. The cables/clips have sagged with time and aren't exactly in the AIM defined locations.
