Fuel line male fittings to "acorn" 396 carb bowls - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Is the male fitting (on the '65 L78 steel fuel line) the same size and thread as (say) used on the '66 and '67 carbs ?
    I have two service LIST 3124's (dates 653 and 874) with the '66-style bowl inlets, and, while at Carlisle, would like pick up the proper (original or repop) fuel line block and lines from pump to junction block, and the lines from the block to front and rear bowls.
    Pic of real 396 bowl (not mine -- I wish ) with brass acorn fitting, for reference.
  • Ray K.
    • July 31, 1985
    • 372
    Re: Fuel line male fittings to "acorn" 396 carb bowls
    Wayne
    The fuel line size is 5/16" steel and therefore the nut is 5/16" inverted flare nut and requires a 1/2" wrench size.
    Ray
