Alternator Help - NCRS Discussion Boards
Alternator Help
    • July 24, 2011
    • 297
    Alternator Help
    I just purchased a '65 Coupe. It is mostly original. I am not sure however of the alternator. It has these numbers on it
    1100668 37A
    4C2 12VNEG
    Can you fine folks tell me if that is the correct alternator for this non air car.
    Mike
  • Carl N.
    • April 30, 1984
    • 592
    Re: Alternator Help
    Believe 1100668 is base alternator for 1964 327
    Believe 4C2 date code is March (C) 2nd (2) 1964 (4)
    Believe you will need 1100693 for base 327 application for 1965
    Check the judging guides or the Corvette Black Book to be sure
    693 37 amp used on a lot of 327 Chevy applications and should not be hard to find.
    Others may chime in with better info than I offer. Check my number to be sure.
    Good Luck
    Carl
    • Don H.
      Moderator
      • June 16, 2009
      • 2257
      Re: Alternator Help
      from what I read in the Corvette Specs Guide, Carl is right on the money. You would want a 693 Alt that is dated no more than 6 months prior to your car's build date. Now I believe that if your car was by chance a first month or two of 65 production (Aug or Sept 64) car, you might be able to get away with a 64 model alternator when it comes to judging. Check me on that one.
      • Jim D.
        • 2883
        Re: Alternator Help
        Check E-Bay. There are several rebuilt ones on there now for $69 that cover most dates .
        • Rick A.
          • July 31, 2002
          • 2147
          Re: Alternator Help
          Mike,
          check with Ken Bruno - he should be able to do a swap with you on a correct dated / restored 1965 alternator - check his website at:
          We specialize in Corvette and other GM Muscle Car Show Quality Delco Alternator, Starter and Generator Restorations.
          Rick Aleshire
          2016 Ebony C7R Z06 "ROSA"
