Radiator support question - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    Okay guys,
    I am getting ready to pull mine out. 1 corner is rusted through at the top but not the bottom. Don` know if I can cut it out and replace the pieces without out it being noticeable. Is there a part number on these. If so, what years does it ru through.? Then the task of finding one begins.
    • 11692
    Re: Radiator support question
    Steve,
    I've had 2 of them repaired, but that was before there was a repro one. If you know a good welder have him look at it after it is sandblasted or dipped (had my mine dipped by the radiator shop). At least there is now a repro if yours is really bad.
    Patrick
    • Paul O.
      • August 31, 1990
      • 1716
      Steve
      Most supports can be repaired you need to have very good metal shaping skills and great welding skills. But with work you can save your original I do not know of a number stamped in the support but finding a great used one is very hard to do and the reproductions leave something do be desired.
      Just my 2 cents.
      Paul 18046
      • Dick W.
        • 10483
        Paul, there is a new game in town on supports. I know that Keen Parts is selling them, so I have been told. The original GM tooling has now been scrapped. (800) 757-KEEN (5336)
        Dick Whittington
          • 43272
          Originally posted by Steve Dunn (53331)
          Okay guys,
          Steve------
          No part number is usually stamped on original or GM SERVICE radiator supports. No GM SERVICE supports are currently available.
          • Paul O.
            • August 31, 1990
            • 1716
            Dick
            Thanks for the info have not heard or seen one that I know but may have with out knowing. Is the fit equal to GM originals that was always a problem with the other reproductions.
            Paul 18046
            • Dick W.
              • 10483
              Dick
              Paul 18046
              Should be equal Paul. I never had any problems with the other repros
              Dick Whittington
