Frame surface rust, C2 - NCRS Discussion Boards
  • John R.
    • November 1, 2005
    • 433
    Have a project that I most likely will not get to for a number of years. Currently it is stored indoors, dry and sometimes high on a lift, four poster vs on a concrete floor. Frame has scaling and surface rust currently. Should I be concerned with the scaling and surface rust becoming more of a problem over time? If so, what would you suggest I apply (oil, rust converter, other?) to treat what I have, so that it does not get worse? Or due to how I have it stored, am I worrying about nothing? Any suggestions on product, if necessary would be much appreciated.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Frame surface rust, C2
    If it is indoors and truly dry, I wouldn't worry about too much further deterioration in the next few years.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • William P.
      • August 31, 2003
      • 135
      I would buy a couple of spray cans of " Fluid Film " and give the frame a spray. Great stuff for rust prevention.
      Regards Bill
      • Gene M.
        • April 1, 1985
        • 4233
        If the scaling and surface rust is a big percentage of the metal thickness you have strength issues. Surface rust is generally not an issue but scaling is a big concern. As the thickness of the metal is greatly reduced in generation of scale.
