58 Rt. inner fender extention - NCRS Discussion Boards
  • Stephen B.
    • August 31, 1992
    • 261
    I am finishing final assemble of my first week of Dec.58 build of a 59 serial #1944. I recently discovered that the original inner skirt on the right side that I replaced had the removable insert like a 58. There is no evidence that this inner had ever been replaced, so my Question is. Could an early 59 have a 58 inner fender ? Has anyone seen this in the past ? Before I cut the now finished skirt and modify to duplicate what I had I need to know how it would judge as is and if this is valid when was the change made.
    Stephen Barrett (21558)
  • Stephen B.
    • August 31, 1992
    • 261
    Re: 58 Rt. inner fender extention
    Surely one of you 58 ,59 judges out there would be interested in this Question.Do I have something outside the norm ? If not at what point did they stop using this extention. Mine is original to the car. I welcome your input.
    Thank You
    • Bill M.
      • April 1, 1977
      • 1386
      I have '59 2520, assembled at the end of December (original inner fender). I don't think it has an insert...not sure what to look for.
      • Stephen B.
        • August 31, 1992
        • 261
        Thank You Bill. What your looking for is at the bottom of the inner skirt, just bellow the voltage regulator were the skirt goes from a vertical surface to a horizontal one. The best example I have found in a book is the Central Corvette cat. 1F page 72 part #141089. For those of you that are curios look straight down past your voltage reg. and if you see a lipp on the skirt with a separate panal attached with 3 screws thats it.
        What I need is for owners of 59s with a ser # pryor to 1944 to investigate this please.
        • Bill M.
          • April 1, 1977
          • 1386
          Originally posted by Stephen Barrett (21558)
          Thank What your looking for is at the bottom of the inner skirt, just bellow the voltage regulator were the skirt goes from a vertical surface to a horizontal one. The best example I have found in a book is the Central Corvette cat. 1F page 72 part #141089. For those of you that are curios look straight down past your voltage reg. and if you see a lipp on the skirt with a separate panal attached with 3 screws thats it.
          Good description of what to look for! 2520 is one piece.
          (This is a 290HP car, which has a different inner fender due to the washer jar being installed on the RH side. I'm assuming that the inner fender was pre-drilled for that accessory and unique to the 290 with washer...)
          • Stephen B.
            • August 31, 1992
            • 261
            Surely there's one of you out there with an early 59 (pre#1944)who is curious enough to get out your flash light and look down at the bottom of the right skirt and see if it is typical of a 58 or of a 59. Just below the voltage regulator.Thank you for any input.
            • Stephen B.
              • August 31, 1992
              • 261
              I'm unable to reserch this issue any further without help and input from one of the many knowledgeable members out there. Jump in and get the discussion started.
