I have found the previous posts that indicate the CV-202 PN 1552729 was used on the 1962 Corvettes until it was superceded by part number 5649561 in Dec. 1961. I think I also have found that 5649561 may cross reference to CV-693. Can anyone verify, that? A later catalog shows CV-693C is 6484851 (I think I read that correctly). What does a CV-693 look like?
I have a small collection of CV-590 and CV-590C PCV valves that I picked up in the 80s at the Pomona swap meet in California. I have one of the short black (2 5/16) valves and the longer version of that (2 9/16). I also have a bright colored version of the long valve and another bright long version but stamped CV-590C. From reading the other posts it sounds like the long valves date from 63 to 64, but the short CV-590 is early 63 or could be late 62. What was the part number of the early CV-590s in 1963? Edit: I have found the part number for the CV-590 to be 5649689 in Oct. 62 (per Dave's post) and then changed to 6421934.
I have a 62 Corvette with RPO242 that was built in February of 1962. So I am trying to determine what the correct valve should be.
